G13 coolant is fine for G12 system?!
Old Dec 18, 2013 | 02:08 PM
Frozenguy's Avatar
Originally Posted by HBAudi
+1 on using only genuine Audi parts for the critical items of the cooling system since they are very involved from a labour standpoint to install.
Pentosin++ is designed for Audi systems from 2006 onwards and contains silicates, which can cause clogging in the earlier systems. Pentosin 'Pentofrost SF' is for systems from mid-1996 through 2005 MY and is without silicates.
Found some Pentosin Pentofrost SF locally for about $11/1.5L!
Thanks for the help
Old Dec 18, 2013 | 06:06 PM
HBAudi's Avatar
Thanks for the help
You will be thankful in the future you chose the specified coolant.
My 1996 B5 Quattro has only had G012 coolant in over 322 000km of use with no issues with the radiator or heater core.
Last year, I needed to replace the air conditioner evaporator due to a small leak and decided to replace the heater core since they are both in the same housing. The sixteen year old heater core showed no signs of leakage nor had any mineral deposits when I examined it.
Perhaps I am just very lucky...
Old Dec 18, 2013 | 08:09 PM
turbo510's Avatar
I just changed out the G11 blue coolant in my '96, with G13 from the local VW dealer, who charged me only about $23/gallon. I drained the radiator, blew out the heater core and oil "cooler" hoses, filled the system with water, drove to operating temp, then purged all the water. Filled with G13 and distilled water 50:50, the resulting color is red. I also found some leaks that I didn't know about. Because the old coolant was so diluted from topping up with water, it evaporated without leaving a trace. But the G13 is 20% glycerin, and left red slimy globs on the garage floor to locate the leaks by.
Old Dec 18, 2013 | 08:20 PM
HBAudi's Avatar
Turbo, thank you for mentioning the distilled water 50:50 dilution. I forgot to point that out earlier.
It is always nice to find the leaks and deal with them than be stranded on the side of the road overheating!
Old Dec 27, 2013 | 04:54 PM
ECS Tuning's Avatar
Sponsor
G13 is perfectly compatible with G12 systems Check out the chart below and our PDF for more information on coolant.
PDF here
Let me know if you have any questions.
Jason
barrystein
Dec 14, 2012 01:29 AM
sshhbequiet
Dec 15, 2010 07:45 AM
belowme
Aug 14, 2007 11:02 AM
gregp1962
Nov 15, 2006 11:58 PM
