Having trouble diagnosing misfire.
Old Apr 9, 2010 | 09:13 PM
A4 2000's Avatar
Default Having trouble diagnosing misfire.
A while back, I got a cel for a misfire in cyl. #4. So, as recommended, I switched the coil pack to a different cyl. to see if the misfire would follow it (which was cyl. #3). Then I got a code for #3 and #4. For one last test, I then switched #3 and #4 to #1 and #2. What's happening now is the misfires are still going on, but not as bad, so it not tripping a cel. Oh, and the misfires only happen under heavy acceleration under boost. I keep trying to drive the car hard just so I can get a code, but no luck. Does anyone have any idea what's going on here? I don't think it could be the plugs since they only have 6k mi. on them. Thanks.
Old Apr 9, 2010 | 11:15 PM
jjcrt2's Avatar
what kinda of plugs are you using? if your chiped u should be using ngk bkr7e's
Old Apr 9, 2010 | 11:59 PM
A4 2000's Avatar
I'm using ngk v power plugs. Could the car not like these plugs or something? I bought the car last year so I don't know if it's chipped or not. I still don't have a boost gauge, so I guess I won't find out until I do
Old Apr 10, 2010 | 09:39 AM
jjcrt2's Avatar
if your not chipped only run oem plugs at manufacture spec gap if you are use the ngk bkr7e's gapped at .028 thats one of the biggest problems i see ppl encounter with missfires besides coil packs
Old Apr 10, 2010 | 10:17 AM
Mike-2ptzero's Avatar
If they are copper plugs then you might want to put a new set in because 6k is plenty on copper plugs. Pull them out and look at them, they might be worn to the point that the gap is too big now.
Old Apr 10, 2010 | 02:10 PM
A4 2000's Avatar
Well, it would be cheaper to try out some new plugs than buy a set of coil packs. I'll probably try that first and see what happens.
mikeaagesen
Aug 30, 2014 11:08 PM
rynmthw3
Nov 8, 2012 07:38 PM
brady0630
Sep 26, 2012 09:46 PM
rtheriaque
Jul 28, 2009 02:40 PM
Texas_Pete
Aug 24, 2008 07:44 PM
