2002 S4 Avant (B5)- Need help diagnosing a misfire
Old Jul 26, 2009 | 11:33 AM
rtheriaque's Avatar
Default 2002 S4 Avant (B5)- Need help diagnosing a misfire
Folks,
2002 S4 Avant, 6 Sp with GIAC software, 101k miles. I have a misfire that I'm having difficulty diagnosing. It's not leaving any traces- no CEL/DTC's, and the VAG-COM didn't pull any codes.
I just did a tune up (plugs, air filter, fuel filter, general cleanup). The plugs that came out were uniform in color and completely clean- no oil fouling. The stock breather hose was just replaced with a cold-weather version (I was having difficulty in winter with freeze-up).
The misfire only occurs at light load (30% throttle or so). It tends to be a morning thing when the air is slightly cooler. It does not happen at all while on cruise control. I monitored the TPS with the VAG-COM and the readout looked smooth and clean, though I do reach 100% before the pedal hits its stop. I vaguely remember reading about that being typical, however.
Any suggestions? Is there anything I can look at/monitor with the VAG-COM? If so, I'll need specifics- I'm brand new to the thing (it's borrowed, anyway).
Many thanks in advance.
Regards,
Rob
Old Jul 26, 2009 | 10:51 PM
bigern45's Avatar
id recheck your plugs and/or make sure the coil packs are on properly and plugged up all the way.. it could be something simple.. maybe a plug was dropped and closed the gap and thats easy to miss....
Old Jul 28, 2009 | 02:40 PM
rtheriaque's Avatar
Thank you for the reply. I should have been clearer- I did the tuneup in response to the problem, so it has performed the same way on two sets of identical plugs.
The plugs are stock NGK's.
nate777
Jan 12, 2014 08:17 PM
brady0630
Sep 26, 2012 09:46 PM
Miron
Apr 20, 2011 04:44 AM
A4 2000
Apr 10, 2010 02:10 PM
sports265
Jul 6, 2009 10:12 AM
