Head Unit Power Wiring
Old Apr 15, 2014 | 04:18 PM
GoremanX's Avatar
I just received that timer module today and played around with it to see if it meets my needs. It's perfect! The default configuration isn't ideal, but the configuration options include what I needed to make it behave exactly as required to match the OEM head unit behavior.
When I actuate the trigger, the module energizes a relay for XX number of seconds or minutes (1 second to 60 minutes, selectable with a dial). So I can use the timer to shunt 12v from the constant power source to the ignition-switched power source for 30 minutes. A couple of diodes will ensure that I only power the entertainment system and nothing else. Technically the timer module can handle an 8 amp load, but I'll only be using it to energize a relay. I'm a big believer in using relays to actuate stuff.
OldAudiA4B5
Jul 17, 2014 12:31 AM
unclemofo
Mar 20, 2013 11:38 PM
Eric9000
Jul 6, 2011 10:49 PM
dblakez06
Jan 5, 2008 03:23 PM
