hEADLIGHT PROBLEM
Old Feb 10, 2023 | 04:15 PM
zzdiesel's Avatar
Default hEADLIGHT PROBLEM
1998 Audi a4 quatro 2.8.
Suddenly headlights quit working.
No dims no brights.
Lifting up on the turn signal lever gets brights.
Also cruise has not worked since I had the car.
Is there a relay somewhere that might account for this?
Wires in the stalk switch maybe.
Old Feb 10, 2023 | 04:26 PM
zzdiesel's Avatar
I forgot to add, check engine light came on on the same drive. Could there be a connection?
Old Jun 29, 2023 | 02:22 AM
97A4WILBER's Avatar
From what I have seen it seems your issues are caused by a bad or melted “combination” switch which is your headlight and cruise control switch. Replace it and you should be good to go. Might last a couple months or never have another issue. Audi did not install a headlight relay from factory if you add one it should never be an issue again.
Old Jun 29, 2023 | 11:45 AM
zzdiesel's Avatar
The ignition switch was the problem.
ebattilana100
Feb 17, 2009 02:13 PM
prsoldier8
Jan 31, 2009 07:54 AM
sineo
Dec 28, 2007 11:53 PM
needhelpinNY
Aug 31, 2007 12:32 AM
devildevil
Aug 9, 2005 06:08 AM
