Headlight question
Is it possible to switch out the orange blinker in the headlight to a clear one or "chrome" without actually having to buy new head light hopefully someone understands what I'm trying to ask here
Do you have one piece headlights or two? Technically, the answer to your question is yes, regardless of the answer to my question.
If you have the pre-facelift two piece headlights, you can very easily and cheaply swap out the orange corner lights for clear ones like these. I ran a set like that on my old 97 for a long time with orange bulbs and they were awesome.
Alternatively, you can upgrade to e-code lights like these. I also ran these on my 97 after the clear corner lights and they were awesome.
If you do have the once piece headlight design, you can remove the orange reflector inside the corner light using this DIY and they will be awesome.
Hope that helps!
Hope that helps!
You have to take the headlights off the car. Then you can pop out the parking light bulb and stick a screw driver through the hole. That'll allow you to break the reflector into small pieces that you can fit through the hole. Follow?
