Headlight washer pump......
Old Dec 8, 2008 | 06:05 AM
410ThirtyValve's Avatar
Default Headlight washer pump......
anyone know whether the headlight washer pump is in the bumper or is it under the hood somewhere?? Just curious if it will be part of a new bumper, should I end up buying one.
Old Dec 8, 2008 | 08:58 AM
hiwords's Avatar
it's attached to the bumper but you will not find a bumper that comes with the washers unless you get a kit or deal from somebody. you changed you name too haha
Old Dec 8, 2008 | 12:40 PM
Tlag's Avatar
Default blind leading the blind?
On my 99.5 there is cylindrical shaped thing behind the right (drivers side) headlight, back in against the fender. It looks like it is connected the the headlight washer system and has a power connection on the top of it. My headlight washers don't work, but thats as far as I've got on trouble shooting it.
I've got a fuel gauge sender and wheel bearing ahead of that project.
Old Dec 8, 2008 | 01:02 PM
hiwords's Avatar
no the washers are pressure activated. there are no electrical connections
Old Dec 8, 2008 | 06:57 PM
TommyGunns's Avatar
Mine has two pumps. One for the headlight and one for the windshield, and I believe they are both on the reservoir.
Old Dec 8, 2008 | 09:10 PM
junya's Avatar
Member
yep two pumps. both are both pressed into the reservoir towards the front of the car.
Old Dec 8, 2008 | 10:22 PM
ludensol's Avatar
where is the switch for it? lol im getting a a4 within the next couple weeks and i want to know where it is
Old Dec 9, 2008 | 12:19 PM
Tlag's Avatar
My headlight washer don't work,... but I think the headlight washer is suppose to come on every time you hit the windshield washer.
Old Dec 9, 2008 | 12:22 PM
Tlag's Avatar
Where does the pressure come from? Couldn't that connection behind the headlight, above the washer fluid tank, be for headlight washer pump?
Old Dec 9, 2008 | 07:42 PM
nitro_rider2001's Avatar
yea when i swapped my timing belt i messed around with the pump assembly... its never worked since i got the car and i pressurized it with compressed air and voila!!! i got shot in the face with old washer fluid.... still doesnt work tho
Clayson
Aug 10, 2013 08:11 AM
Jeffla
Nov 25, 2010 10:09 AM
gabeguimaraes
May 22, 2009 04:47 PM
gabeguimaraes
Mar 29, 2009 01:24 PM
Trey25
Mar 22, 2008 11:06 PM
