Headlight washers
Old Feb 21, 2008 | 11:42 AM
DJTR's Avatar
Default RE: Headlight washers
lol tried all that mine just won't fire at all, I think the pump is dead I just don't know where it is located..... Anyone know??
Old Feb 21, 2008 | 12:15 PM
Trey25's Avatar
Remove left front tire and splash guard. There are two pumps, the one for the headlight washer is more to the bottom left. You can't really miss it, the hose to the sprayers is connected. Unplug the wire connector and hose then pull out the pump, without cracking the reservoir. There are a couple ways to test it. Before you remove it have someone activate washers and listen for the pump, no sound then the pump is bad. Or, use a multimeter and check continuity across the leads as well as voltage test on the wire connector.
Old Feb 21, 2008 | 12:32 PM
feerocknok's Avatar
I'm curious as well. I don't want mine to work. They dont wash at all, and spray down my hood, making it look like hell when it dries.
Old Feb 21, 2008 | 06:49 PM
Redrum1's Avatar
I wish mine would quit working as well. It doesn't matter if the headlights are on or not or how long you hold the stick they spray. I'm always finding my washer fluid empty and Know I only used the winshield washers a couple of times since filling it up.
Old Feb 27, 2008 | 04:16 PM
DJTR's Avatar
Well now that I know where it is I'll be checkin it out soon
Old Feb 27, 2008 | 05:05 PM
CTown's Avatar
i have never seen mine work. I tried holding the windshield washer for 10 secs, a few different times. I ended up running out of fluid very quickly, but my headlights never got wet! I got a 99.5 by the way.
Old Feb 27, 2008 | 06:12 PM
awwdii's Avatar
i am going to switch mine around so they spray the opposite direction. Just in case I see a tuner I don't like my audi will pee on them to mark its territory.lol
WGA
Audi Q7
Jul 28, 2008 10:14 PM
Lopster99
Mar 6, 2007 08:03 PM
dlinbh
Oct 16, 2005 04:13 AM
///A4
Sep 7, 2005 07:50 AM
