headliner
Old Mar 22, 2010 | 07:34 PM
jt's A4's Avatar
Default headliner
ok so im confused on how to get the headliner out of my car can some one help me out please and thanks
Old Mar 22, 2010 | 08:02 PM
ketteman32's Avatar
ok this is pretty easy to do but gonna seem overwhelimng to do a lot of parts to remove. remove the a-pillars. bpillars. cpillars and rear trim at rear window. just pulls down. remove rear light switch from headliner, remove front lights and sunroof panel. should have two trim pieces that come off then two screws and fall right down. to removed the healiner there will be a screw where the front panel was removed very small screw. and in the rear it just snaps into place and if you have sunroof you have to unclip the ring around the sunroof area its easy just slide sunroof open and you will see a black ring that goes around sunroof and into the headliner just clip it off and the headliner should fall down. lay down the two back seats and slide it out through the trunk so you dont crease it.
Old Mar 23, 2010 | 10:24 PM
jt's A4's Avatar
ok thanks man already have all the pillars off just having trouble with the rest but thanks for telling me the rest
Old Mar 23, 2010 | 11:18 PM
x2nervisx's Avatar
after you get the "oh ****" handles off, the headliner is only held onto the roof around the sunroof by clips. They just snap off. You'll have to tug on the headliner down and you'll feel the headliner snap down. There's about 8 clips holding the headliner around the sunroof. No way to get to the clips except for a firm tug down on the headliner.
Southern6er
Aug 17, 2010 07:09 PM
roll4ever
Feb 2, 2009 02:12 PM
feerocknok
Mar 28, 2008 11:18 AM
A6V6
Oct 4, 2007 10:21 AM
gmatov
Jan 3, 2006 02:47 AM
