Hearing the turbo at very low psi?
Old Aug 3, 2012 | 02:28 AM
DanaB6's Avatar
Default Hearing the turbo at very low psi?
Its pretty weird i think, not sure if its normal or not, but i doubt it is because it does not really make sense, i shouldn't be able to hear my turbo at 0-5 psi right when im in a higer gear going at a slow speed and giving gas i hear my turbo and its usually around 0-5ish psi. Any advice? Normal? Symptoms of a Bad n75 (hope it is ), due to a boost leak? Thanks in advance.
Old Aug 3, 2012 | 06:53 AM
FASTER's Avatar
Tech Slut
Why wouldn't you be able to? I hear mine when its in vacuum.
Old Aug 3, 2012 | 07:37 AM
CCA4's Avatar
That's because your turbo is the size of a beach ball and sucks small animals and children into it..
OP, it's normal. Especially if you have removed part/all of the stock air box. I can hear mine just about all the time. As long as it isn't making any horrifying dentist drill type noises you're fine.
Old Aug 3, 2012 | 09:17 AM
FASTER's Avatar
Tech Slut
Are we talking about turbos or Jess's ***?
Old Aug 3, 2012 | 09:19 AM
CCA4's Avatar
ROFL
Spirals
Dec 17, 2007 09:50 PM
endle55
Jul 25, 2006 02:46 AM
smokey727
Apr 2, 2006 09:22 PM
