Heater Core Shot, '01 A4!!
Old Feb 1, 2009 | 08:24 PM
Salt Lake 2M's Avatar
Default Heater Core Shot, '01 A4!!
Hey all,
Been a while since I've posted, ran into another problem (had a fair share so far..) and hoping for some advice here..
So the heater core started leaking on out '01 A4, luckily it's not behind the dash but still in the engine compartment but nonetheless the dealership says it should be changed out which is going to cost around $1300... I was wondering if I could just by-pass the whole thing, I'd lose the cabin heating but I could probably live with that for a while and just put an extra sweater on. Am I understanding the functioning correctly, if I keep the thermostat on cold with the fan on minimum would that effectively by-pass the heater core as well and stop the leakage so I can at least drive it for a bit longer?
While I love the car (in the periods between issues), it's an '01 and has around 120k miles, so I'm thinking about upgrading and therefore would prefer not to spend the $1300 or so and use that money towards a newer car..
All advice welcome, thanks in advance!! Oh, we're in Salt Lake, if anybody knows of a cheaper place for labor (Alpine doesn't change them unfortunately), please let me know as well!!
Thanks again!!
Old Feb 1, 2009 | 10:35 PM
chaos92287's Avatar
the way i understand it is coolant doesn't enter the core until you turn on the heat. there is a valve in the hose preventing it, so as long as you don't turn on the heat, it should not leak
Old Feb 1, 2009 | 11:22 PM
That's how I understand it as well, so we'll give that a shot and see how it goes.
Thanks, all other advice welcome still!!
Old Feb 2, 2009 | 09:03 AM
dhavi4226's Avatar
I've beentold by a reliable source that BARR's leak works well. That is their fairly new product.
http://www.barsproducts.com/1111.htm.
Cost is a little high but may be worth a try.
Old Feb 2, 2009 | 09:28 AM
Redrum1's Avatar
Bars Leak has been good through the years. I have used it many times. If I were to try one it would be this one.
http://www.barsproducts.com/PLT11.htm
Good Luck...
Old Feb 2, 2009 | 11:32 AM
jeffha4's Avatar
Hey, the two shops I most frequently visit, are autograff motor works, and alex's auto hauz. I couldn't tell you the labor for each, but they always have done quality work. alex's auto hauz deals with mainly audis, some other europeans, so they have a really good knowledge of your car. autograff is just very reliable, and they will look your car over completely and give you an estimate. or they could probalby just quote you over the phone. Autograff is in downtown SLC, alex's is out in sandy.
Old Feb 2, 2009 | 12:18 PM
Thanks for ther advice guys!! I have thought of products like Barrs, however due to the size of the leak I suspect it's a crack rather than a pinhole and have my doubts about whether a product as such can fix it..
I'll give Autograff a call as well and see how much they charge.
Thanks again!!
e30bmw318is
Dec 9, 2009 04:00 PM
vgo
Jan 21, 2009 06:07 PM
93_90s21
Jan 24, 2007 04:21 PM
r1100spa
Sep 26, 2005 03:21 PM
postalworker
Sep 5, 2005 05:36 PM
