Heater going crazy.
Old Jul 11, 2008 | 05:51 PM
Tweaked's Avatar
Default RE: Heater going crazy.
Is there 12v supplied to the fan from the HVAC c.u. when the fan runs up and down like that?
Old Jul 12, 2008 | 01:32 AM
Mattzcrazy's Avatar
Go behind the glovebox and next to the fan motor housing is a module with a six pin harness connector. This is the fan control box or regulator.
Mr. Tweaked hit this nail on its head a few posts back. Our OPs excellent transcription of the CC head numbers show a problem on data channel 18 & 19
Possible cause for the engine on/off failure differences is probably the supplied voltage going from 12 to ~14.
Old Jul 12, 2008 | 02:55 PM
audimon's Avatar
Ok, thxs
But which of the pins in the connector should have 12v.
Also when the scale is showing the fan going up and down in its speed,the fanactually is doing nothing, in other words it don't run its stationary when the engine is running, but if I turn the ignition from fresh the fan will run and can be controlled. It only when the engine is actually started, is when the problem starts.
Thxs again
eos815
B7 Models
Jan 3, 2015 11:33 AM
e30bmw318is
Dec 9, 2009 04:00 PM
juzzo
Mar 8, 2008 01:12 PM
PandaXpress
May 7, 2006 08:10 PM
