HELP!! 01 a4 1.8t quattro air loss sound and loss of power
Old Mar 14, 2012 | 11:51 PM
steven.whyte's Avatar
i dont know if this makes a difference but before all those problems started i noticed that the engine temp gauge wasnt working correctly, it would go up a bit when i drive but when i stop for awhile it would go back down to cold. also the fuel mileage went down alot lower...
Old Mar 15, 2012 | 08:50 AM
CCA4's Avatar
The coolant temp thing sounds like a stuck thermostat. When the car is moving and the engine is producing more heat you're ok but then when you stop the thermostat stays stuck open. This could also be impacting your gas mileage because the engine is more efficient at the proper operating temperature. I very much doubt that's related to the bucking/loss of power you're feeling though.
Old Mar 15, 2012 | 11:53 AM
willo1010's Avatar
check the hose down by the turbo under the air filter for a tear. IF it's the cause look for a silicone type (they seem to last longer)
troysherk
Jul 11, 2012 12:38 AM
kaotiklivin
May 19, 2011 02:54 PM
90quattroNoge
May 3, 2008 01:45 AM
xhale1
Nov 16, 2007 08:20 PM
jmatheson2003
Jan 19, 2007 04:12 AM
