Help.
Old Aug 3, 2010 | 05:13 PM
lakeside's Avatar
Unhappy Help.
I want to replace my right front wheel bearing this weekend and can't find a place with a press around here (Palatine, IL).
Do you know someone who would do it? If you live around me and have a press please let me know.
Old Aug 3, 2010 | 10:26 PM
emily0918's Avatar
i took my wheel bearing apart and brought it to Sanels or Robins Auto Parts, don't know if they have those near you, hope this helps : )
Old Aug 3, 2010 | 10:35 PM
chocalotstarfish's Avatar
Super Moderator
any auto shop should have a press that can do it.
Old Aug 3, 2010 | 11:00 PM
lakeside's Avatar
Hey thanks, could you tell me where these shops are located? Thanks.
Old Aug 3, 2010 | 11:25 PM
FASTER's Avatar
Tech Slut
Old Aug 3, 2010 | 11:44 PM
01AvantQTM's Avatar
Banned
Harbor freight sells cheap presses. Picked up a 6 ton for 89 dollars...in prep for tackling my front right wheel bearing. (Hope the 6 ton has enough clearance for the spindle... should of gotten the 12 ton
Old Aug 4, 2010 | 07:25 AM
ImTheDevil's Avatar
I blew a Harbor Freight 6-ton apart on a rear bearing - bent the whole top part of the frame about 25 degrees. I pull the spindles off and take them, along with the new bearing, to Goodyear and have them pressed for $28 each, then go home and reassemble.
