Help 2.8-pause then stars
Old Nov 4, 2009 | 02:37 PM
2.8Luv's Avatar
Member
Exclamation Help 2.8-pause then stars
Starting yesterday my car won't start immediately as usual. It's a manual and it feels almost like I'm not pressing the clutch to start but I am. The only thing I've noticed to be different is I no longer hear that "squirting" noise from the gas tank like it's running it up to the engine. (It usually does that noise obviously pretty loud if I can hear it in the cabin.) Now it kind of sounds like a "psst" "psst" every 5-10 seconds. Of course I have the typical improper gas reading when it gets low so I ran out of gas the other night and my CEL is on now, but the last time that happened the light turned off on it's own after a few days.
I'm afraid to go get a CEL reading in fear that if I break down at the shop they'll try to force me to get it fixed there or tow it away.
When I turn the key to ignition it's below the 12V on the meter but doesn't seem to me that the battery is the problem. I drove all day yesterday and got back in 20 minutes later and it still did it again- the battery should have been charged it's less than 3 years old. If I leave it at ignition and wait a minute then try to crank it pauses for a moment then turns over. Now it's happening on like the third try. I feel like I have to leave it there and wait for something to happen before it'll crank.
I've been meaning to change the fuel filter since it's never been done.
-I'm at 114k 30v AHA, no knocking, no rougher idle
Old Nov 4, 2009 | 02:41 PM
carbonOX's Avatar
Go to auto zone, they will read the cel for free
Old Nov 4, 2009 | 02:42 PM
Andrew149's Avatar
battery's can go bad even at brand new if you live in cold weather its even worse if you go to hot and cold all the time 3 years old is not uncommon for a battery to go bad if your running the ac and stero all the time its prob time to go
Old Nov 4, 2009 | 03:02 PM
2.8Luv's Avatar
Member
That's Chicago weather described perfectly. So you think it's the battery? I'll try giving it a trickle charge and see if it cranks right away after. Thanks
Old Nov 4, 2009 | 03:17 PM
Andrew149's Avatar
yep well there you go autozone battery's are junk ive been through so many of those i buy all my battery's at sears they last a long time im happy with the battery's there but nothing else
Old Nov 5, 2009 | 02:46 PM
2.8Luv's Avatar
Member
yup. It seems when I ran out of gas I kept trying to start it, that's what wore down the battery. I never drove it long enough to let it recharge enough. I guess I panicked
toxicmanA4
Apr 29, 2015 03:53 PM
Scottrpt
Sep 29, 2013 01:53 PM
Gary T
Aug 31, 2012 09:39 PM
Brians01A6
Feb 12, 2010 12:23 AM
jdkluck
Apr 26, 2009 11:38 AM
