help 98 a4 quattro
Do you get the vibration when accelerating? Cruzing? Idle? And what do you mean not ECU communication? Are you saying you can't call into the ECU with vag-com? We need some more details.
Any mods on the car?
Josh
Josh
ORIGINAL: fatpat210
i got the same car and the same problem what it is is the power output stage on the intake its sending misfires to the cylinders
If your scanner works only when it's "cold" (makes absolutely no sense), are you able to see retrieve any fault codes?
People that "know cars" and need help provide many more details than you have provided us with.
Get the code to your radio to see if it works. If it doesnt, someone may have had an aftermarket radio installed at one time, and then put the stocker back in. If the stock radio wiring was messed with, it caninhibitcommunication to the ecu from the OBD port.
