help 98 a4 quattro
Old Jul 26, 2008 | 05:17 PM
asbestos2001's Avatar
Default help 98 a4 quattro
i just bought a 98 a4 quattro 1.8t
i got a problem when it warms up get a wierd vibration and no ecu communication
when cold no codes present
pls help
mike
Old Jul 26, 2008 | 06:50 PM
Audi_Skydiver's Avatar
Default RE: help 98 a4 quattro
Do you get the vibration when accelerating? Cruzing? Idle? And what do you mean not ECU communication? Are you saying you can't call into the ECU with vag-com? We need some more details.
Any mods on the car?
Josh
Old Jul 26, 2008 | 06:54 PM
thanks for gettin back so fast no mods on the car
vibration when accelerating goes away atound 60km/h
i plug in my snapon computer and no communication
only works when its cold
Old Jul 26, 2008 | 07:00 PM
Do you have an aftermarket stereo?
Josh
Old Jul 26, 2008 | 07:01 PM
original but non functionel
Old Jul 26, 2008 | 07:22 PM
Hmm...
Have you tried to go to autozone or some place like that and had them try and scan it?
Josh
Old Jul 27, 2008 | 11:33 AM
nothing works i know someone with vag com still dont work
Old Jul 27, 2008 | 02:22 PM
fatpat210's Avatar
i got the same car and the same problem what it is is the power output stage on the intake its sending misfires to the cylinders
Old Jul 28, 2008 | 09:30 AM
i dont think its a misfire of the cylinders engine seems to be runnig really good
feels wierd i know cars but this one really has me stumped
Old Jul 28, 2008 | 12:22 PM
onepoint8tee's Avatar
ORIGINAL: fatpat210
Vibrations could be anything, and how can you be so confident when you don't know if his CEL is flashing, you havent diagnosed his car, etc. You are just throwing a problem/solution out there because it happend to you. That is not the kind of help we need around here. Thanks anyways.
If your scanner works only when it's "cold" (makes absolutely no sense), are you able to see retrieve any fault codes?
People that "know cars" and need help provide many more details than you have provided us with.
Get the code to your radio to see if it works. If it doesnt, someone may have had an aftermarket radio installed at one time, and then put the stocker back in. If the stock radio wiring was messed with, it caninhibitcommunication to the ecu from the OBD port.
