HELP! CAN'T REVERSE!!!
Old Apr 9, 2008 | 08:41 PM
aramkim's Avatar
Default HELP! CAN'T REVERSE!!!
So yeah, last night it was pouring rain like crazy and I drove through a couple spots that were flooded pretty bad on my way home.
Now this morning I get in my car and realize that I can't reverse.
The gears won't shift into reverse.
Drive and Neutral along with Park is fine...
What's wrong with my car...?
Did something just get wait and so I have to wait till it dries?
Or is this gonna be a costly repair..... = (
Please HELP!
Old Apr 10, 2008 | 01:30 AM
01AudiA4's Avatar
Default RE: HELP! CAN'T REVERSE!!!
It could be a sensor. I dont really see how the tranny would just go bad from getting wet? I would take it to a shop of the problem proceeds. Its kind of a bitch when you have to push a car back out of the driveway everyday....
Old Apr 25, 2008 | 10:38 AM
Crunk's Avatar
Is your Transmission display Flashing?
Old Apr 26, 2008 | 04:16 PM
YoungGentleman86's Avatar
Its your Multi-function switch (Neutral Safety switch). I drove through a puddle and mine did the same. Thought it was my tranny (so did my regular shop) but the guys at the transmission shop said that my multi-function switch got damaged. I'm replacing mine right now. Should have my car back on Monday.
Make sure you mention that it could be that cause I did at my regular shop and they looked lost (no longer my regular shop) and when I mentioned it to the guy at the transmission shop he said he had the same feeling.
MAKE SURE YOU CHECK THAT FIRST BEFORE SOMEONE MAKES YOU BUY ANOTHER TRANNY (I almost did this).
Good luck man Keep us updated.
Old Apr 26, 2008 | 09:12 PM
david9999's Avatar
Did you get water inside your car? The transmission control module is on the floor of the passenger side and if it gets wet it will be toast. Otherwise see above.
Old Apr 27, 2008 | 02:02 AM
crsf29's Avatar
First thing you should do is check the codes with an OBDII reader. Autozone will let you borrow one as well as Advance. Mine did the same thing as yours is doing right now, rain storm and all. You can clear the codes with the reader. You might get reverse and overdrive back, you might not. Checking the codes will tell you whether it is the TCM or not. If it comes up saying "shift circuit" or somesuch ****, it isn't your TCM. You can totally avoid the shop in diagnosing this problem. Mine is the switch inside the selector. Overdrive and reverse are engaged by a solenoid controlled by the TCM. If your TCM cant get a good signal on which gear your car is in, it will fail safe into "limp mode", and your PRND32 will be lit differently on the dash. If the problem were your TCM, your car would switch gears funny, jump into reverse at odd times and all kinds of other bad stuff.
hope this helps
Cory
Old Apr 27, 2008 | 02:48 AM
Drocka4's Avatar
Is it an automatice or a manual? Do you think that the linkage may have slipped somewhere when it got wet? Just tryting to help generate ideas, good luck.
capecodallroad
May 29, 2011 03:23 PM
deacon2
Apr 7, 2011 12:36 PM
TylerA4
Mar 20, 2008 10:40 AM
garciajd
Aug 8, 2006 07:10 PM
RUGBY23
Nov 19, 2005 05:40 PM
