HELP! Car Dies @ Stop Sign!!
Old Mar 13, 2008 | 09:58 AM
aramkim's Avatar
Default HELP! Car Dies @ Stop Sign!!
So I'm driving today, car sounds like a lawnmower, and then shuts off when I come to a stop.
I try to start up the car again and it hesitates.
I'm in an intersection, so I can't do anything else...
So I turn the key while giving it some gas and it starts rough.
I pull into an autozone and they give me this code.
P1565 Manufacture Control | Vehicle Speed | Idle Speed | Aux Cont.
Along with a bunch of misfire codes...
What the hell is going on?
Please help guys...
Old Mar 13, 2008 | 03:45 PM
hb972.8q's Avatar
Default RE: HELP! Car Dies @ Stop Sign!!
do you have a 12v 2.8? if so it is your icv valve. just pull it out and cleen it ( carb cleaner).and reinstall. http://www.audiworld.com/tech/engine Idle Control Valve Removal and Cleaning
Old Mar 13, 2008 | 06:33 PM
aramkim's Avatar
Do I do the same thing for a 1.8T?
I don't have the 2.8
Old Dec 13, 2008 | 07:41 PM
A4bauler's Avatar
Default I'm having the same problem you did
Hello what ended being wrong with your car? I have a 1.8T too and I'm also having the same problem.
Old Dec 14, 2008 | 09:45 PM
Audi_Skydiver's Avatar
Might want to try your CTS (coolant temp sensor). it's only $30 from the dealer and will cause ALL KINDS of problems. Mine went out in my A4 when i had it and it wouldn't start, ran like crap, got misfire codes, and other random codes.
Josh
Old Dec 18, 2008 | 04:13 AM
dnasians's Avatar
i had the same thing, at a stop i shifted to neutral, and the car died. turned out that it was a vacuum leak.
milds3vn
Mar 21, 2007 06:13 PM
prospectmotoring
Dec 15, 2006 09:53 AM
sami.durrani
Nov 18, 2006 07:49 PM
kathan21
Dec 27, 2004 04:40 AM
