Help Dash Light ON?
Old Aug 26, 2008 | 07:45 PM
a4audikid's Avatar
Default Help Dash Light ON?
i have a 99 audi a4 2.8L, has a light ON on the dash, dont kno what it is, anybody.
The light is yellow with a circle and dash line,s around it?
Old Aug 26, 2008 | 08:02 PM
The Bosno's Avatar
Use the seach feature of the forums to find threads that will help you.
Other than that look at your car's manual to see what the light means, then go to autozone and they can check the code which will tell you what's wrong.
Old Aug 26, 2008 | 08:33 PM
Maroon98's Avatar
Should be the ABS/brake warning light. ABS might not work or a sensor's messed up somewhere
Old Aug 27, 2008 | 05:45 AM
JrAdrock's Avatar
Banned
if you have a 99.5 A4 and the light looks like this (0) it is your brake pad wear sensor. Time to do a brake job. Double check your manual.....
Old Aug 27, 2008 | 09:48 AM
CRAZYHAWK's Avatar
(O) can also be caused by low brake fluid in a B5.
Old Aug 27, 2008 | 10:45 AM
a4audikid's Avatar
yea its a 99.5 with yelow light dat looks like (0).
Old Aug 27, 2008 | 11:15 AM
jiggleo's Avatar
the last is a washer fluid warning. how many beeps does it give you? your manual will tell you all you need to know for that. Also the search feature is there for a reason although I can understand why that wouldn't work with your spelling. You write like someone that's to young to drive.
Old Aug 27, 2008 | 12:58 PM
a4audikid's Avatar
Sorry about the writing. am use to writing like that, am 21yrs old & this is my first audi. use to have hondas.
Trickstar
Aug 8, 2013 12:10 PM
Cyberhero
Jun 8, 2011 06:12 PM
rchachi
Dec 21, 2009 08:27 PM
rob18859
Feb 17, 2007 12:02 AM
