Help with Diverter Valve
Hi, there;
Need help selecting a DV. Have a 98 A4 1.8T Quattro and just replaced the turbo. I put a stock K03 back (used w/low miles) and since that'll be completed fairly soon and I'm planning to get a chip, I decided to change the stock DV, since the car has 180,000 miles on.
I need suggestions on what DV to buy. I've heard the N710, but I'd really appreciate your opinion. I'm not planning on tunning the car much more than that (no turbo upgrade, no injectors, no FMDIC...at least it's not in the plans). Since I'm gonna replace the DV, I don't want to put a stock one, I'd like something that would make it easier to breathe with the chip.
Thank you for your help,
Fabian.
Fabian.
I'm sure this issue has been addressed before, so I appologize in advance, but I coudn't find it. If you know the post, would you take me there, please? Thank you for your help.
I have this http://www.goapr.com/Audi/products/r1.html. this requires no mtce
most have this http://www.forgemotorsport.com/conte...oduct=FMCL007P, requires some mtce.
or if you want that bov sound, you can get this http://www.forgemotorsport.com/conte...roduct=FMDV004requires some mtce and caused idle issues and epc issueswith my car.
I really don't need much, but since I'm replacing the turbo (for K03 OEM standard),I might as well replace the DV and reduce the chances and since it's old and stock. For what I understand then, both the Forge 007p and the APR R1 would work...especially when I'm not planning on pushing the tunning to the limit, but only adding a chip. Thank you for the info and opinions, I appreciate them. Anything else I should know about? Any other DV I should consider? Any preferences?
FtMyersAudiFreak
May 25, 2005 11:35 PM
