help me please
So I started my car and I put the car in drive and it shifted it self into that tripnotic thing. I never use that. So I turn the car off and started it again and it did the same thing. It won't drive in normal drive. So I had to use 4th gear. What's wrong????
It's stuck in 4th gear? Are all the lights for your gears on the dash highlighted in a red box? If so it's tranny limp mode. You have a probelm with your tranny control module or more than likely your tranny range switch/sensor. Gotta get it to a shop that knows a little something about VW/Audi. The dealer if you don't mind the labor costs.
no its not stuck in fourth. when i put the car on D and puts it self on that tripnotic whatever its called. my cars a auto. i have that things that i can switch to the easy person stick shift. when it switches to that it still doesnt work. so i had to put the gear into fourth so it could move.i can D, 4, 3 ,2. another question how fast can i go in fourth??
it "automatically" throws itself into tiptronic?
so when you're sitting in "D", on the display, you can see "1" followed by a 2, 3, 4, and 5?
and why in the **** are you using 4th to start......... at least do 2, then shift to 3, and then to 4.
edit: for elaboration; in tiptronic mode, you can see which gear is selected by looking at the display. in regular automatic it'll still have that display, but with different letters/numbers.
i shift the car into drive. by it self it put the car into tripnotic. im not pushing the thing over to turn it on. so i go one does into 4 and the car moves. the car will not move while its in D or tripnotic
