Help PLEASE! Cylinder 2 misfire...
Old Dec 17, 2010 | 11:05 PM
djcctek's Avatar
Default Help PLEASE! Cylinder 2 misfire...
Cylinder 2 misfire. Changed all 4 plugs swapped coil 2 with 3 and still misfire in 2. havnt checked fuel injectors or replaced any packs yet. also 99 1.8t b5 preface. Any suggestions on how to test fuel injectors? control module u say??? Hmmm???
Any helps asap will be appreciated. workin on it in the morn.
Thanx
Old Dec 17, 2010 | 11:47 PM
sshhbequiet's Avatar
i would replace the coil packs too. i had this problem in my truck a few months ago (lightning, i know, not an audi) and it fixed the problem....of course i dont know how much coil packs for a4s run though...
Old Dec 18, 2010 | 12:07 AM
djcctek's Avatar
yeah i was thinking that, about $60 bucks or so from advanced for lower cost higher quality BWD brand. that with the coil $300+. i can do the labor easily. probably gonna check the injectors and maybe along with that compression. It is colder than a withes tata in a brass bra, here in good ol New England. how is that lightning (rear wheel only, right?).
thanx
Old Dec 18, 2010 | 01:21 AM
evelluser's Avatar
If the misfire didn't follow the coil, its not the coil thats messed up. Don't put the money into that. Get a compression test done. Othen than that, I don't have any ideas.
Old Dec 18, 2010 | 05:56 AM
colony777's Avatar
probably your ICM, glad i dont have one. make sure your plugs are at .28
Old Dec 21, 2010 | 12:24 AM
djcctek's Avatar
Default yahoo! she is purrin good...
ok thanx guys for ur help... It def was the ICM... I did a search and no one had anything... found one just sitting on the firewall of an A4 and also found a HUCO in a passat on a hill. 12' drop to a street. leaned against a pole my brother had to squeeze his hand in to release the hood on a passat and there was AEB and a virtually brand new HUCO. plus a crappy set of coils, all for $50. plugged it in after a new set of plugs and some high quality octane boost. she rides like a dream.
there is the drivers side bearing that wiggles a bit. it should hold for a while. full synthetic oil change. i need to do the damn timing belt and water kit... 107,000... it just snowed a good 4 - 5" tonight and she drove prime.
chiao...
Russ Heinrichs
Aug 18, 2021 12:39 PM
and b
Feb 10, 2014 11:52 AM
ThePizza
Jul 23, 2008 05:16 PM
ricky0323
Feb 29, 2008 01:35 PM
