help please... how many cc should i run on my KO4?
I noticed my car doing that once in a while but I'm all stock. It seems to do it less now though after a couple of fuel injector treatments. Could this be from a bad fuel filter or something?
so i talked to an APR dealer and they said they don't have a program for the AEB with KO4.... they only recomend using a 4bar regulator.... so i'm just going to keep my 370cc injectors spraying about 330cc and deal with my sorta crappy idle.... sounds like it misses every once in a while... but the car fly's!
The biggest issue with running a K04 on a K03 is the fact that the tune is set with enough fuel at idle/PT/WOT. When you throw on larger injectors to fix a lean issue at WOT you end up with really rich fuel trim for idle/PT. This is why there are K04 tunes.
Have you checked your fuel trim readings(block 032) and your AFR readings at WOT?
