HELP- serious engine problems a4 b5
Old Jun 1, 2008 | 10:31 PM
hessiannate1984's Avatar
Default HELP- serious engine problems a4 b5
I have an 99a4 avant 2.8 and i have not had a problem in the 6 months i have owned it. I was installing my subwoofer today and caused some damage nd autozone is closed tonite so i cant say the diagnostic. I disconnected the battery and i installed the amp when i hooked everything back up and turned it on, the engine was lacking serious power and fluxuating like crazy.my subwoofer amp went out but i checked all fuses on the car and stereo and nothing blew out. Started car backup, wouldnt hold idle and dies and checkengine light on. It chokes and bounces up and down at 1500 rpm andstruggles idling at 3-400 rpm then dies. It tops out at 40 mph and wont shift when i rev.catalytic converter? fuel pump? O2 sensor ?
Can someone please help me out before i break my wallet at the auto shop ? any suggestions
thanks
Old Jun 1, 2008 | 10:44 PM
ImTheDevil's Avatar
Default RE: HELP- serious engine problems a4 b5
You need to try and limp it to an AutoZone and get the scan done first -the codes will be a big help in diagnosing the problem.
Old Jun 1, 2008 | 10:52 PM
dmelkumo's Avatar
Did you by any chance connected amp to your ecu instead of battery?
EXTRA
May 24, 2012 06:55 PM
Jake2.0T
B7 Models
Nov 7, 2011 11:57 PM
maniorta
Apr 18, 2010 12:39 PM
painted600rr
Jan 9, 2008 03:08 AM
JohnnyPG
Apr 29, 2007 12:54 PM
