help - the turbo glowing
Old Apr 27, 2010 | 09:49 PM
tony_chu123's Avatar
Default help - the turbo glowing
97 Audi A4 1.8TQ
The turbo always glowing while normal driving.
When I scanned the car via vag com, there is no falut code. but readiness 15:
o2 sensor heating passed
o2 sensor: failed or incomplete
Evaporative Emission: Failed or incomplete
Cat converter: failed or incomplete
Does this mean I need to replace both O2 sensors and Cat converter?
Thanks!
Old Apr 27, 2010 | 10:10 PM
Msnickbroderick's Avatar
Actual WIZARD
Mine glows on a daily basis, its no big deal. Check 02 harness/connections, and all vaccum lines. If you can, pull the cat and look through it, if you can, all good, if its clogged/broken then its obviously bad
Old Apr 27, 2010 | 10:18 PM
hiwords's Avatar
your 02 sensors are getting old and are going bad. you probably have a small evap system leak too. the cats should be good though.
Old Apr 27, 2010 | 11:08 PM
joenelson7687's Avatar
Mine glows too and I always thought it was normal. Any diagram on evap system?
Old Apr 27, 2010 | 11:18 PM
Dallas09's Avatar
Readiness doesnt necessarily mean you have a problem... It just might mean you have to go through a couple driving cycles before it says complete or "passed" (all of that stuff is for emissions testing). If you had a problem with you cats efficiency the car would throw a diagnostic code, if one of your o2 sensors was bad the same thing would happen, or you car would run poorly. Basically look at it as Incomplete, you definitely dont need a new cat or o2 sensor because of that.
Old Apr 28, 2010 | 01:23 AM
kriptonik's Avatar
Mine doesn't glow. Maybe this will help me...
Old Apr 28, 2010 | 02:09 AM
thanks guys, will replace the o2 sensor first.
Old Apr 28, 2010 | 08:27 AM
CCA4's Avatar
that kriptonik, always good for teh lolz.
tony, glowing is fine. dentist drill-type noises are bad, smoke is bad, fire is bad, explosions are bad. As Dallas said, you might not need a new cat yet, it could just be mad because your pre-cat O2 sensor is on the fritz. Try replacing that and then re-scanning in a coupla weeks.
Old Apr 29, 2010 | 10:01 AM
Default culprit
is ICM problem, got random misfire, after change the coil packs, still random misfire. Change the ICM then ok. Thanks,every body,but I changed the Pre-Cat O2 sensor anyway the car is way much smoother.
csstaticx
Feb 25, 2010 09:48 AM
kbrookst
Nov 21, 2009 01:36 AM
Bltprf502
Nov 20, 2008 02:43 AM
///A4
Jan 11, 2006 04:33 PM
mike18t
Dec 1, 2004 04:33 PM
