hi flow cat
Old Feb 9, 2008 | 10:33 PM
m5racer's Avatar
Default RE: hi flow cat
ORIGINAL: A4speed
that magnaflow hfc is only 2.25" where if your getting borla exhaust, its 2.5". A shop could make it work, but you should have 2.5" turbo back exhuast. I have a techtonics dp and hfc www.techtonics.com
im pretty sure that borla cat backs are 2.25 beucase i have one and it is, unless within the last year or so they have changed that
Old Feb 10, 2008 | 01:58 AM
A4speed's Avatar
ORIGINAL: m5racer
ORIGINAL: A4speed
yeah, you are right actually, for some reason i think of techtonics and borla exhausts as the same thing, probably because one of the shops here uses techtonics for dp and hfc and uses borla for cat-back.
Old Feb 10, 2008 | 08:48 AM
BeatjunkieXL's Avatar
how'd the non fouler mod work out? if it did, how much did it cost you and what else did you have to do to pass emissions? I have to replace my stock cat, so HFC is what im lookin for, if test pipes arent an easy or easier option
thanks in advance
Old Feb 10, 2008 | 04:38 PM
chaos92287's Avatar
borla is 2.25"
techtonics is 2.5" w/ borla mufflers
and the non-fouler will only let you pass emissions if they dont test your car under load (some places cant test AWD cars). if they do, your fvcked. only way your passing under load is with a cat
Old Feb 10, 2008 | 07:14 PM
tooxtreme8813's Avatar
get a HFC it has the all the advantages of test pipe and no drawbacks
Old Feb 11, 2008 | 07:16 AM
thanks guys, now i gotta decide what diameter is best, 2.5 or 3", for a future gt28rs setup...
Old Feb 11, 2008 | 08:10 AM
chaos92287's Avatar
ORIGINAL: tooxtreme8813
and is 3 times as expensive
Old Feb 11, 2008 | 11:54 AM
  #18
jeffha4's Avatar
So will the Labree HFC fit my 97? I noticed on like the magnaflow, it was 2000 or later. So I was just wondering if it's the same with the labree?
Old Feb 11, 2008 | 02:00 PM
  #19
A4speed's Avatar
ORIGINAL: chaos92287
borla is 2.25"
ok cool, thanks for clearing that up for me.
Old Feb 11, 2008 | 02:02 PM
  #20
A4speed's Avatar
ORIGINAL: BeatjunkieXL
both will be fine for a gt28rs setup, but 3" does allow more air flow, so if you can afford it you may as well get the 3"
