hi need help lowering
Old Dec 12, 2009 | 04:27 AM
djnick's Avatar
Default hi need help lowering
hi all iv just bought a 1999 s reg audi a4 se b5 1.8 (non turbo) and it seems to sit a bit high on the wheels just bin thinking of sticking sum 18" alloys on it to replace the stock 16" but im worryed it will look silly and to high...
any ideas guys
cheers in addvance
Old Dec 12, 2009 | 04:50 PM
kriptonik's Avatar
Generally, you'd have to lower the car to prevent looking like a 4X4.
Although the car should sit close to the same height as stock if you get the right size tires.
Old Dec 12, 2009 | 05:23 PM
dubbed_up_daz's Avatar
what he said,but id lower it some if upping the wheel size anyway
Old Dec 12, 2009 | 06:45 PM
hiwords's Avatar
i'd lower it about 1.5 in or so. it'll sit right above the tires of the 18s. idk what they offer where you live but judging from the engine configuration you have you're not in the US. i'd pm Siena or docurley. they are in europe and can help you more i think
Old Dec 12, 2009 | 11:07 PM
A4 2000's Avatar
Generally the best way to go is to lower the car first and then add some rims after that. If you want your speedo to stay accurate, you should try to end up with the same outside diameter of the tire. So this is a way that I always remember figuring out the dimensions.
16/55 series
17/45 series
18/35 series
19/30 series, but would still be bigger than desired.
mikeeace
Dec 1, 2009 12:02 PM
petes4
Mar 9, 2008 08:51 PM
100mhz
Jun 21, 2007 12:57 PM
mark80scu
Apr 13, 2007 08:07 PM
T_REV_17
May 6, 2006 01:16 AM
