HID Headlight Out
Old Nov 25, 2010 | 11:19 AM
chickeneater's Avatar
Default HID Headlight Out
Driver side HID headlight is out and I tried replacing it with a new one... $77 later and it still does not work. The passenger headlight works fine. I haven't looked at the wiring, but could it be as simple as a fuse? Are there separate fuses for each headlight? What else might the problem be?
Old Nov 25, 2010 | 11:21 AM
dragonrage's Avatar
I think there are separate fuses but I don't have an HID model so I'm not 100% sure.
Old Nov 25, 2010 | 11:33 AM
CCA4's Avatar
There are separate fuses for each headlight, would be worth looking into. Also, when you say you replaced "it", are you referring to the bulb? The ballast could also be on the fritz.
Old Nov 25, 2010 | 11:35 AM
Yeah, I replaced the bulb. How can I tell whether the ballast is bad?
Old Nov 25, 2010 | 11:43 AM
dragonrage's Avatar
You should be able to swap ballasts from side to side.
Old Nov 25, 2010 | 11:45 AM
CCA4's Avatar
Well I'd start with the fuse first. If the fuse is good, swap the bulb from the other side that you know works. If it still doesn't light up, its a safe bet the ballast is bad.
Old Nov 25, 2010 | 12:08 PM
Dozanti's Avatar
My HIDs are picky, I had my HID fog go out (one of them) after being on for 5 minutes with the car sitting. About an hr later I tried them and it came on. Check the wiring and what not
Old Dec 3, 2010 | 12:36 PM
Where can I pick up a cheap ballast?
Old Dec 3, 2010 | 01:03 PM
CCA4's Avatar
The OEM ballasts are not cheap. You can get a chinese one for like $10 from vvme.com but you'd have to hack it and wire it in yourself
Jrmiller
Feb 25, 2013 03:03 PM
Influentialstylez
Mar 29, 2007 04:30 AM
rkohan
Mar 20, 2007 04:16 AM
