HID problem. Help?
Old Feb 28, 2008 | 10:17 PM
eurodynasty's Avatar
Default HID problem. Help?
so I installed hid's on my car awhile ago, and they worked great for awhile, and recently the passenger side light doesn't turn on, then I flip my lights on and off a few times and it turned on, but now it won't ever turn on. I checked the bulb and it looks fine so I'm assuming its a problem with my ballast? Any ideas anyone?
thanks!
Old Feb 28, 2008 | 10:34 PM
CIA's Avatar
CIA
Default RE: HID problem. Help?
the connections are good? i mean they do contact?
jason955's Avatar
Why don't you try hooking the working bulb to the other ballast. If it works, it's the bulb, if not, it may be the ballast.
Old Feb 28, 2008 | 10:36 PM
ORIGINAL: CIA
Yes they all contact
Old Feb 29, 2008 | 03:05 PM
less_of_me's Avatar
I had the exact same issue. I am 99% sure that it is your connections. What HID kit did you buy? Was it from visionbulbs by chance? Anyway, what I did was this -
I took some needle nose pliers and squeezed down on the connectors between the Ballast and the plug going to the bulb. Should be two connectors. Anyway, after I did that, I tested the lights and they both worked so I took some electrical tape and taped both of the connectors together and I haven't had a problem since. Hope that helps.
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
