Hiding boost leak
Old Jul 20, 2010 | 09:24 PM
Desert Fox's Avatar
Default Hiding boost leak
So I was taking an onramp pretty spiritedly when I heard something start going clack clack clack really loud for a few seconds fro the rear passenger side. I straightened out and it stopped. looked to see smoke or anything, nothing. So I started to get on the pedal to merge, and I realized the car was sluggish. In fourth it was only getting like 16 lbs as versus the 20 I was running when I was pinned in 4th.
I heard the boost leaking as I got off the freeway and was pulling into a gas station. Couldn't locate the source and all of my intercooler piping was still connected. I took it home and had my friends listen while I brake boosted, and It was coming from around the turbo/diverter valve area. I have a forge splitter, so I figured that wasn't the problem, but took it off anyway and put the stock broken dv back on. It boosted 5lbs max at any gear. put the forge back on and still maxes out at 16, and the car bogs horribly when you get on it and boost that much. It threw a check engine light for long term fuel trim rich as well. I reset that but, I know there has to be a boost leak somewhere. problem is I cant find it.
I took brake cleaner and sprayed it on all the clamps except for the one the connects to the turbo (didn't want fire) and nothing changed. But there is deff. a leak, I just cant find it. does this sound like something any of you have heard of before?
Old Jul 20, 2010 | 09:40 PM
onepoint8tee's Avatar
I wouldn't use the stock dv as a comparison because it can't stand up to a k04 tune and as you said it's broke...?
It could be a bad coil pack (or cracked spark plug insulator) that has not yet registered as a misfire. A 4lb boost leak probably wouldn't make the car bogg down and react like this. A bad coil pack or plug would, especially when you are trying to get on it hard. I had a cracked plug insulator (the white porcelin part) and these were my same symtoms. It took a lot of driving around for it to finaly register the misfire (crack crack crack) and make the CEL blink. Plus you have AEB engine which the coil packs are ticking time bombs anyways.
The ecu should scale back boost/timing, etc. if not put you into limp mode if a rich codition is present.
Old Jul 20, 2010 | 10:50 PM
chocalotstarfish's Avatar
Super Moderator
I would say for finding leaks this has been my #1 way of finding them!!! real easy to locate when there is no other sounds but leaking air and since the car isnt running you can move you hands all over to try and feel the leaking air.
http://www.a4mods.com/index.php?page...boostleak.html
Old Jul 20, 2010 | 11:52 PM
joenelson7687's Avatar
+1 on the tester. Check any hoses that have bends in them. I had a pcv hose with a 90 degree bend by the manifold that sprung a leak.
Old Jul 21, 2010 | 02:19 AM
Desert Fox's Avatar
Yeah I can hear the leak, and I just replaced a coil last week, I know for sure what a misfire feels and sounds like.
But im going to do that test tomorrow after work and see if I can find the leak that way. If not, ill have to look around and see what else I can find. This happened a few weeks ago but it was the pvc pip I used at one point till I could get a metal pipe. It bent inwards on itself making the hole smaller for the air to go though making it louder.
Old Jul 21, 2010 | 02:39 AM
I might be way off. Whenever I hear about symptoms that are remotely close to something that I've experienced, I get all excited and **** my pants.
Old Jul 21, 2010 | 04:37 AM
Desert Fox's Avatar
Haha, I do the same. Theres something I think Ive seen before, but it turns out to be totally different. I thought I could have all the problems in the world by now with my car. I was wrong.
Old Jul 21, 2010 | 11:24 PM
Desert Fox's Avatar
Found it!
With my handy tool tool thanks to something starfish showed me.
Old Jul 22, 2010 | 08:15 AM
Super Moderator
that's a legit way to do it man, I'm tellin' ya!
Old Jul 22, 2010 | 12:13 PM
Good job! Never seen a leak sprung there.
to4xxx
Jun 8, 2012 11:56 AM
onepoint8tee
Jun 27, 2007 04:38 PM
truckjunky87
Feb 8, 2007 12:33 PM
fenderstrat1184
Dec 21, 2006 02:35 AM
a4bsix
Jul 6, 2006 04:28 PM
