high rpm hesitation
Old Feb 12, 2008 | 07:46 PM
sdboarder84's Avatar
Default high rpm hesitation
installed new plugs today, it idled great very smooth reved with no roughness but on the way to work I got on it and the is a high rpm heistation. it is like it wants to go but it is acting as though it is hitting some sort of limiter right at about 3500-5000
Old Feb 12, 2008 | 08:00 PM
Bogie's Avatar
Default RE: high rpm hesitation
did you gap them correctly?
Old Feb 12, 2008 | 08:03 PM
yup. .28
Old Feb 12, 2008 | 08:06 PM
cincyTT's Avatar
I'm make believe
You reset the ecu after the misfires?
Old Feb 12, 2008 | 08:08 PM
i vag comed it and cleared the codes. does that mean it was reset?
Old Feb 12, 2008 | 08:17 PM
cincyTT's Avatar
I'm make believe
Yes. What is the boost doing at the time?
Old Feb 12, 2008 | 08:26 PM
the boost is all normal in first and second it will hold at 16-17psi for a while and then drop to about 10-11psi and in third through 5th it will boost the same and drop to about 14 psi
ndinsmore
Sep 22, 2013 09:36 AM
Turbo4me
Jul 22, 2010 04:55 PM
ianjm
Feb 24, 2010 06:51 PM
goburgie
Sep 7, 2009 08:37 PM
bhj0887
Oct 8, 2005 12:09 PM
