High RPM problem with a '96 A4 2.8 quattro.
Old Apr 11, 2009 | 02:09 PM
NickBroderick's Avatar
Default High RPM problem with a '96 A4 2.8 quattro.
I'm looking at a used Audi and everything is fine except while pulling out for a test drive I realized the car revs high, to about 2,300 RPM, before it starts moving. It feels like it needs to shift but it doesn't. It's an automatic. Is anyone familiar with this problem?
Edit: The o2 sensor is being replaced, so could that be the problem?
Old Mar 13, 2012 | 09:54 PM
Bump, still wondering. Anyone?
Old Mar 13, 2012 | 10:24 PM
cincyTT's Avatar
I'm make believe
I don't know much about autos but I do know they still use clutch packs. Could be a warn out clutch disk(s) or could be as simple as dirty fluid. Swap the trans fluid and move from there.
Old Mar 13, 2012 | 10:35 PM
ou2mame's Avatar
i doubt an a2 sensor would control the contact between engine load and the tranny... the problem is something with the tranny, because if you hit the gas and its not moving, its stuck. lol, maybe a really, really, really frozen caliper? does it roll easy in neutral? try throwing it in neutral and see if it stops prematurely to a halt. i don't mean going fast, like 5mph. i've never had any tranny problems with mine (knock on wood), just hit 125k the night before last. i have flushed it a few times since i got it, once when i first got it because i bought it 5 or 6 years ago with only 35k miles on it, and then once again when i got the car stuck in a flood. maybe the ebrake was on? that's really high to be pushing before something moves, i'd definitely look into it before handing over any money.
Robert Skidmore
Jun 24, 2012 01:19 PM
FV49
B7 Models
35
May 15, 2011 03:20 PM
craigrobertson
Jan 26, 2011 04:33 AM
eislee56
Sep 2, 2009 09:54 PM
Alfetta
Jan 8, 2009 11:01 AM
