High Speed Wobble?
Old Jul 18, 2012 | 02:17 AM
RAE0694's Avatar
Question High Speed Wobble?
Hey, this is my first post and i have a question. When I drive at speeds 55+ you can feel what I believe to be the front axles wobbling slightly and the wheel has a small shake to it, no noise. When I bought the car (about 3 months ago) I was told the front axles should be replaced soon, could they have been referring to the CV axle? Would that fix my wobble problem? Please help...
Old Jul 18, 2012 | 03:11 AM
bshusted's Avatar
I'd check for wheel balance before looking at the CV joints, but I imagine that a bad CV could cause trouble.
Old Jul 18, 2012 | 04:05 AM
MyA4Mobs's Avatar
Stock or aftermarket rims?
Old Jul 18, 2012 | 06:47 AM
02A6Beau's Avatar
standard rule is that if you feel it in your hands it is an alignment problem, possibly could be the axles that you mentioned, or some other front end suspension issue. if you feel it in your backside it is a balance, or some other wheel/tire problem
CV problems are typically only noticable when you are going around turns. you will hear the ticking/grinding noise
keep in mind these are generally generalized generalizations. your problem may be unrelated.
good luck
Old Jul 18, 2012 | 08:59 AM
CCA4's Avatar
I second/third a wheel weight. I lost a wheel weight on my old A4 and only noticed it at speeds above 55mph. Got all 4 wheels balanced and it went right away.
Old Jul 18, 2012 | 01:16 PM
Sheasta's Avatar
I can feel a pull from shitty tie rod ends on the highway. Its hard to go perfectly straight.
oilart
Oct 27, 2012 04:11 PM
imaudi5000
B7 Models
10
Mar 7, 2011 09:58 PM
a4blk
Dec 12, 2010 11:12 AM
caminos
Jun 29, 2009 11:33 PM
