How do you test the fuel pump? 1997 2.8
Old Mar 4, 2012 | 11:07 PM
gregp1962's Avatar
Default How do you test the fuel pump? 1997 2.8
The car won't start. The fuel pump isn't making any noise when I turn the key on or crank it. I jumped it at the relay under the dash. Still no pump noise. This makes me think the pump is blown. I'd like to run 12v directly to the pump to see what happens. But there are 4 pins on the pump. How do I know which pins to put the 12v power to?
Old Mar 4, 2012 | 11:17 PM
02quattrokev's Avatar
Instead of runing power directly to the pump why don't you check for power to the pump. If you have voltage there then the pump should work, if not then find out why you don't have voltage to the pump.
Old Mar 5, 2012 | 12:24 AM
gregp1962's Avatar
Good idea. But which of the 4 pins should the voltage be in?... And should there be voltage anytime the key is on? I heard that it will not get voltage unless there is at least 13 RPMs.
Old Mar 6, 2012 | 09:12 PM
What's your VIN i'll see if i can pull up a diagram and tell you which is power.
Old Mar 6, 2012 | 09:19 PM
A quick way to just check would be to ground your negative lead of your DMM and touch the pins individually with your red lead and see if you have any voltage across the terminals.
skihigh2299
Oct 11, 2015 05:54 PM
jsethwerner225
Nov 14, 2014 01:55 PM
mbertoli
Oct 3, 2008 03:57 PM
username
Jul 17, 2005 10:56 AM
rnbguy
Jun 29, 2005 11:07 AM
