how hot does the exhaust manifold usually get on my bt a4 ?
Old Aug 2, 2010 | 01:08 PM
flynnr's Avatar
Default how hot does the exhaust manifold usually get on my bt a4 ?
ballpark anyone have an idea of how hot these get? 500F? 1000F?
Old Aug 2, 2010 | 02:11 PM
shortyxc's Avatar
If i had to venture a guess, I would say around 700F. But then again that was pulled from nothing.
Old Aug 2, 2010 | 02:30 PM
FASTER's Avatar
Tech Slut
1000 at idle, 1500 at wot is about right
Old Aug 2, 2010 | 02:39 PM
shortyxc's Avatar
No kidding? Little bastards get pretty hot lol. Is that for the giant sized turbo you've got or do they all run about that high?
Old Aug 2, 2010 | 02:40 PM
CCA4's Avatar
is this a "just because i'm curious" kinda question or do you actually need to know for somethin? If its the latter you might think about drilling and tapping the mani for a EGT sensor/gauge setup?
flynnr's Avatar
http://www.034motorsport.com/fluids-...ted-p-609.html
just ordered that... good up to 2100F lol thats 10x hotter than water boils at should hold up...
Old Aug 2, 2010 | 02:42 PM
flynnr's Avatar
the bolts that hold my turbo to my mani keep coming loose after like two weeks for some reason... i couldnt find ANYTHING else that went up even past 500F... permatex's hottest rated stuff they offer is 500F
sucks it was $40 but whatever itll be nice to not ever have to worry about them again...
Old Aug 2, 2010 | 06:49 PM
Mike-2ptzero's Avatar
yeah those would be EGT's inside the manifold, so the manifold temps will be slightly lower then that. The HPC coating for turbo manifolds/dp/housings is good for 1600-1700 degs.
Flynn - If you have bolts that keep backing out you might to look at using a APR bolt which you can tq down to about 40-45 ft lbs. If your not making them that tight they will always back out.
Old Aug 2, 2010 | 07:29 PM
flynnr's Avatar
this will be the easiest way i think... in order to get the bolt out of the back i have to pretty much take everything out minus the exhaust mani.... (poorly designed log manifold ugh... need to upgrade soon for my own comfort...)
cshideler
Mar 1, 2011 05:32 PM
sirfalconx
Feb 1, 2007 05:46 PM
True_Pinoy
May 5, 2006 06:54 AM
david9999
Nov 20, 2005 08:36 PM
hexion
Jan 10, 2005 02:14 AM
