How much to fix sunroof?
Old Jul 17, 2012 | 06:07 PM
joshy_squash81's Avatar
Default How much to fix sunroof?
How much would it cost to fix a sunroof on my a4? I think it's something electric but idk for sure, it doesn't leak.
Old Jul 17, 2012 | 07:03 PM
CCA4's Avatar
Can you describe the symptoms? The switch and the rails that the glass slides on are both common points of failure for the sunroof. Neither will be cheap to fix if you take it to a dealer or indie shop, but both are fairly easy fixes if you're handy with a wrench
Old Jul 17, 2012 | 07:13 PM
vgo's Avatar
vgo
Mind of its own?
Read through this
AudiWorld Tech Articles
Old Jul 18, 2012 | 07:20 AM
redmond1501's Avatar
The easiest fix is to clean and bend the little contacts in the sunroof switch. This fixed my phantom sunroof symptoms. If you search there is a DIY.
Old Jul 26, 2012 | 05:31 PM
I tried this but I couldn't get the thing open to get to the contacts.
Old Jul 27, 2012 | 09:44 AM
Dozanti's Avatar
You shouldnt need it to be open to get to the contacts. There is a DIY around here that shows how to remove the switch itself, disassemble it, clean the contacts, and re-assemble.
Edit* http://www.a4mods.com/index.php?page...s/sunroof.html
mrocke440
Nov 20, 2010 09:11 PM
tariqahmad
Oct 16, 2009 11:49 AM
18T
May 15, 2006 08:27 PM
a6speed
Dec 10, 2005 07:18 AM
TheHolyGhost
Aug 10, 2005 01:31 PM
