How to remove Cluster wire harness?
Old May 12, 2009 | 01:22 AM
audiA4gm's Avatar
Default How to remove Cluster wire harness?
I have to get an inspection done, and I am going to remove my ABS light in my instrument cluster above the steering wheel so I can pass. We completely removed the ABS after the module was fried....
Question: Removing the cluster was very easy, however I could not figure out how to remove the 2 wire harness' that are connected to the back. Can anyone fill me in on how to remove these properly?
---Also, does anyone know the best way to remove the ABS led light?
Old May 12, 2009 | 01:48 AM
ghost6303's Avatar
in NY i believe they plug into the OBD port to run diagnostics durring an inspection. removing the light wont change the fact that you will have codes stored for the ABS.
Old May 12, 2009 | 10:20 AM
Vhanfinnel's Avatar
Ha, if I was still in NY it would be extremely easy for me to pass inspection. All I have to do is take my vehicle up to my uncle's shop. Almost everything he does for me is free and when it's not, it has about a 95% discount on it. I guess that's one of the perks of being family of the manager.
Old May 12, 2009 | 12:16 PM
audiA4gm's Avatar
So what do you suggest I do? Brake light is flashing (I already filled fluid and it continues to flash) and ABS light are on due to removing my ABS system completely. Anyone in upstate NY (cap region) know of a lax shop where I can pass inspection?
Old May 12, 2009 | 01:24 PM
ghost6303's Avatar
the only way you can get past a scanner is by fixing the problems or going to a shop that doesnt plug into the car. although im not 100% sure they care about ABS anyway, its not emissions related, and im not sure they care about your safety equipment. you arent required to have ABS and not all cars do. if that is your only problem you might as well try and see. if they complain about it then explain to them what i just said.
Old May 12, 2009 | 01:45 PM
audiA4gm's Avatar
Thanks ghost, I wasn't aware of that. I'll give it a try at the most bootleg shop I can find and see what happens.
spdun
May 26, 2012 11:14 AM
cccp907
Jun 14, 2010 01:07 PM
wezal
Jan 29, 2009 03:11 PM
YounGMessiah
Oct 3, 2008 01:35 PM
savagebeast
Jun 7, 2008 08:41 PM
