HVAC codes - troubleshooting
VAGcom scan shows the HVAC codes below. Any suggestions where and how to start with the troubleshooting/fix?
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 D
Component: A4 KLIMAVOLLAUTOMAT_D75
Coding: 04162
Shop #: WSC 06325
VCID: 29570979F97F
4 Faults Found:
01297 - Sensor for Vent Temperature; Footwell (G192)
30-00 - Open or Short to Plus
01296 - Sensor for Vent Temperature; Center (G191)
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
01582 - Signal for Coolant Temperature
Coding: 04162
Shop #: WSC 06325
VCID: 29570979F97F
4 Faults Found:
One symptom: no cold air (AC not working).
Haven't had a chance to monitor other functions (is it holding a set temperature, etc.)
Is any of the codes pointing towards:
- low pressure in AC
- leak in condenser
- bad compressor clutch
- bad compressor
Is VAGcom showing codes if any of the above is present?
Just want to find out if the issue is more controls/electrical/sensors rather than mechancial (condenser, leaks, compressor).
- leak in condenser
- bad compressor
What happens when you try to turn on your A/C, do any other codes come up, does the snowflake stay on or shut off right away? As far as I know those codes you listed wouldnt cause the A/C to stop working. Actually if your A/C was low on pressure, you should get a code for the switch.
спасибо, интересное чтение
_________________
foydali hilo betfair-da bepul yuklab olishni boshlaydi - grand mondial kazino tizimga kirish - grand mondial kazino sayti
_________________
Спасибо, +
_________________
fonbet com nima bo'ldi , grand mondial kazino pul olib chiqish , kazino Vegas o'yin
_________________
01296, 1996, 2007, 8l08200432dlbl, a4, air, audi, b5, blower, code, codes, cold, communication, controller, hvac
