hwo to fix my non-cold ac???
Old Sep 4, 2008 | 04:38 PM
fritz's Avatar
Default hwo to fix my non-cold ac???
alright, it doesnt work now, how do i recharge the thing?
the fan still turns, i just need to know what i need to do to make it cold again.
i coudlnt find a diy on audidiy.com
thanks,
fritz
Old Sep 4, 2008 | 04:41 PM
euro_2nr's Avatar
A shop can recharge it. Shouldn't take too long or be too much $$$, bout the same as if you buy your own kit. But make sure you check for leaks first
Old Sep 4, 2008 | 04:45 PM
fritz's Avatar
can any shop do it, like a gas station or should i go to an audi/european specific shop?
Old Sep 4, 2008 | 04:51 PM
euro_2nr's Avatar
Egh... its simple, straight forward mechanics. Go to a reputable lube shop. They'll know how to do it right.
Old Sep 4, 2008 | 04:59 PM
cincyTT's Avatar
I'm make believe
If i remember right the AEB cars like you have only have a high pressure side so you need to get an adapter for it. In that case, its best to just pay a shop to do it. Think the quick lube places can even do it for you while you wait. Should be looking at $75-150 for it to be done depending on how much freon you need and labor rates. However when they do it, they remove all the air in the system so it will be extremely cold
Old Sep 4, 2008 | 07:02 PM
JrAdrock's Avatar
Banned
It might not be that you need a recharge. The temp. flap motor does go bad at times. People who's car has one go out, try all kinds of things and spend all kinds of money only to find out it was the flap motor. I came across something about that once. A little involved to replace, but the forum post I saw found a possible short cut. I believe you can pull your glove box, and remove the kick panel on the center console to access the motor just enough to see if it is operating when you change the temp on the climate control. If it doesn't, try changing the position yourself. If you get cold air when the A/C is turned on, that is your problem. I will try to find the article for you.
Check out this link to run a diagnostic on the climate control system through the climate control display.
http://www.audiworld.com/tech/int6.shtml
Old Sep 4, 2008 | 07:40 PM
JrAdrock's Avatar
Banned
I found it. This might help you test the motor before you go out and spend money on things you might not need. Good Luck. Link below....
http://forums.audiworld.com/a4/msgs/2827215.phtml
Old Sep 4, 2008 | 07:46 PM
auditech79's Avatar
Thats only on the 96 A4.
Old Sep 4, 2008 | 10:47 PM
cincyTT's Avatar
I'm make believe
I knew it was an older one, just not sure which
Old Sep 5, 2008 | 02:22 PM
fritz's Avatar
cool, thanks all for the feedback!
its finally hot here in the bay area, ~90 degrees
dlcain
B7 Models
Jun 18, 2014 02:56 PM
jinxonator
Feb 25, 2010 02:46 PM
motojoeis01
Dec 20, 2009 11:22 AM
M3Armand
Oct 17, 2007 11:08 AM
