I dont know whats wrong now.....piston ring?
Old Dec 16, 2009 | 02:49 PM
patrixx006's Avatar
Default I dont know whats wrong now.....piston ring?
ok so my car has been running great the past couple of months and i just changed the oil 2 days ago...
its a 1997 audi a4 1.8t quattro with a stage 1 apr tune testpipe and exhaust
so i was driving last night pulled into my neighborhood and floored it... and it kind of gave out, once again im running 17 pounds of boost...so im thinking maybe a piston ring? does that sound right?
i havent driven it since but when this happened i put it in second and took it easy, no problems
also i want to add that sometimes on startup it blows some smoke and smells like its burning oil.
i neeeeeed the car for work tomorrow night so i would appreciate anyone that knows anything!!!!!
thanks
Old Dec 16, 2009 | 03:11 PM
pyropenguin's Avatar
What color is the smoke? blue or white?
Grab a compression tester and run a compression test. How many miles are on the car? If a piston ring failed then there is no way you're going to have the car fixed by tomorrow night, but I REALLY doubt that's what happened.
Old Dec 16, 2009 | 03:14 PM
Mr. Phil's Avatar
when u say gave out do u mean it like bogged out like it was gonna die? or what? and when it blows smoke is it black or white smoke? and how often?
Old Dec 16, 2009 | 04:12 PM
Lyman_T's Avatar
Turbo oil seal. No or little boost needed when you take it easy, she's fine. Start pressurizing, thar she blows......
Old Dec 16, 2009 | 04:22 PM
ImTheDevil's Avatar
What Lyman says makes sense and I'd buy that. Definitely worth doing a compression check and also an ECU scan too though (never know if something is in there that didn't trip a CEL). If you find a cylinder with low compression, add a teaspoon of oil to that cylinder and redo the compression test. If the number rises significantly it's a ring problem. As stated above though, that's probably not that likely.
Old Dec 16, 2009 | 04:42 PM
Mr. Phil's Avatar
u think he could be getting some blowby too? maybe turbo is going bad?
Old Dec 16, 2009 | 04:51 PM
dragonrage's Avatar
turbo is probably more likely given the loss of power mainly under load, though rings can still be a possible problem.
Old Dec 16, 2009 | 05:02 PM
Are you still making boost?
Old Dec 16, 2009 | 09:24 PM
patrixx006's Avatar
i mean it wasnt gonna give out it just like kinda stopped for a second and then it was fine..
yes im still boosting.
its white smoke, pretty much every cold start or after driven hard.
Old Dec 16, 2009 | 09:51 PM
white smoke is coolant. Your turbo is toast or your headgasket is leaking....
