I fixed my car, sorta
Old Mar 21, 2008 | 12:56 AM
erikas3's Avatar
Default I fixed my car, sorta
Hello.I used to have a 0psi boost issue and I fixed it by replacing the turbo actuator, sorta. Now, the car is finally boosting. All I can say is that I'm in love . However, I don't think that it's boosting all that it should. I have the Speedtuning chip which is supposed to bump me up to 18psi. However, the most I have seen was about 11psi in 2nd with the pedal mashed. I'm pretty sure that the actuator is installed correctly. Is there anything else that I can possibly check to maybe gain back the few promised psi? Thanks.
Old Mar 21, 2008 | 01:42 AM
qUaTtRoA4's Avatar
Default RE: I fixed my car, sorta
what type of boost guage do you have?
when I was stock I had a autometer sport comp II boost guage that said I spiked at 11/12 and held at 8/9
then I got my VDO which never/ever read past 8.5 or so stock....
are you sure that your ecu was actually chipped?
have you EVER spiked at 18?...
I have three different guesses
#1- you have a crazy freakin boost leak
#2-your ecu was never chipped
#3- your boost guage is installed incorrectly/it was installed improperly
glad to hear you are boostin again....thats some good headway!
Old Mar 21, 2008 | 01:47 AM
erikas3's Avatar
ORIGINAL: qUaTtRoA4
Hi, I have a VDO.. I will be checking the line tommorow to make sure that it's all good.
1. I doubt that I have a boost leak since the car was shop tested and they did not find a single leak.
2. Unless Speedtuning somehow messed up, I should be chipped.
And I am not boosting again, it is actually the FIRST time I am boosting.. Yeah, my car was like a bus before this..
Old Mar 21, 2008 | 10:37 AM
awwdii's Avatar
Do you have an MBC or are you running the n75?
Old Mar 21, 2008 | 10:43 AM
erikas3's Avatar
N75.
Old Mar 21, 2008 | 10:55 AM
awwdii's Avatar
Have you considered installing a MBC? Might help you control your boost levels a little better also get a quicker spool response.
Old Mar 21, 2008 | 11:46 AM
erikas3's Avatar
ORIGINAL: awwdii
I'm a poor 17 year old so mods don't come that easy [8D]. However, once I replace my rear wheel bearing, I just might have to get a MBC..
Old Mar 22, 2008 | 04:10 PM
01afour's Avatar
2 things.
1 its the chip. i bought a speed tuning chip and i only boost at 10lbs peak. dont try to get it fixed casue the guy will do nothing for you, i tried. just save up and get ur car tuned locally. sorry to be the one to tell you.
and 2, an MBC is about $20-30 brand new, and their everywhere if you want a used one. where do you live cause i can get u a used one for about $15 and mabye $2-3 shipping.
Old Mar 22, 2008 | 11:34 PM
erikas3's Avatar
ORIGINAL: 01afour
2 things.
Damn, hopefully it's not the chip. Otherwise I will be pissed off and out of my money [:@].
I will be trying to give the MBC a go once I have the money to buy one.
Old Mar 23, 2008 | 12:43 AM
awwdii's Avatar
I turned down my radio while I was driving yesterdayand my rear wheel bearing was humming ain't that a b!tch. We're on the same boat this is my 7th wheel bearing I have had to replace on this car. Cheap bearings Suck!
