i put my test pipe on
Old Jun 21, 2008 | 01:05 PM
B5Bobby's Avatar
Default i put my test pipe on
i put my test pipe on yesterday morning, it took me a little under 3 hours. kind of a lotof work, it went pretty smoothly though. i went to autozone to get the non-foulers b4 i put it on. they had the 18mm ones in stock, i drilled themout so the o2 sensor could fit and they bolted right on.
i definetly noticed a difference in performance and my car sounds GREAT! i havent got cel yet =)
Old Jun 21, 2008 | 01:19 PM
ST1FFY's Avatar
Member
Default RE: i put my test pipe on
my testpipe is on its way right now its scheduled to be here monday,
what tools doi need to install it?
on a scale of 1-10 how hard was it?
and would i be able to do it with just some friends?
Old Jun 21, 2008 | 01:37 PM
B5Bobby's Avatar
yeah you should be able to do it with a couple friends, i did mine by myself lol there was a couple times where an extra hand couldnt of hurt.
id say from 1-10 it was about a 7 or 8 lol idk it was pretty tuff.
as far as tools.
a lot of different length socket extensions, 13mm and 17mm sockets
******universal joint socket extension! so you can maneuver the socket through some tight spots. i think without this it would of been a lot harder.
i have an HKS intake with a heat sheild, i took out my filter and the heat sheild to get to the cat easier and without taking the intake out i dont think it would have been possible to take out the cat.
Old Jun 22, 2008 | 08:42 AM
ST1FFY's Avatar
Member
ok im so pumped... did you notice a change in gas milage? or atleast a significant one?
my k&n 57i intake is coming on monday as well i may do both while im in there
did you use a do it yourself or instructions or anything like that?
Old Jun 22, 2008 | 08:49 AM
ST1FFY's Avatar
Member
one friend told me that it could possibly really drop my gas mileage
Old Jun 22, 2008 | 01:24 PM
onepoint8tee's Avatar
Keep in mind it's even more "tuff" to do if you have tiptronic/auto tranny. The tranny is much wider and makes the gap tightwhere you are looking up through/maneuvering your tools. Also fwiw AEB engines take much better to the non-fouler trick than ATW and AWM engines. Last I heard, Unitronics (BT chip) and APR are the only makers who offer a test pipe program that keeps your CEL off when the secondary 02 fault is stored.
Speaking of-
I have a stock cat off a 2000 1.8t w/ 80kish miles on it. If anyone wants it as a replacement or to gutt out to make your own test pipe, PM me.
Old Jun 22, 2008 | 05:42 PM
ST1FFY's Avatar
Member
well that sucks because mine is a tiptronic haha,
how do you know which engine you have?
Old Jun 23, 2008 | 06:52 PM
Look here or here
97-99 1.8t = AEB
00 1.8t = ATW
01 1.8t = AWM
Old Jun 23, 2008 | 10:51 PM
thepirate's Avatar
of course i have an AWM engine and i'm installing (fingers crossed) my testpipe this weekend....and i have a tip/auto tranny....i might have to recruit my dad to help me, he has way more patience with stubborn bolts and tight working space.
Old Jun 24, 2008 | 11:28 AM
ST1FFY's Avatar
Member
mines a 99.5 so im geussing i have an atw and also tiptronic so does any one have a diy or instructions on this?
