ideas to solve pinch bolt problem once and for all
Old Nov 11, 2011 | 10:37 PM
zadeluca's Avatar
The other, more labor-intensive idea, is to jack up the front of the car once a month, reach in and break it free, and tap it out an inch before reseating it.
this is exactly what i do. well, not once a month, i do it at every oil change. its actually quite simple because you can reach it over the tires without taking the wheels off. i had to drill both of them out entirely when i did my control arms...
Old Nov 11, 2011 | 10:53 PM
ImTheDevil's Avatar
And drilling them out really sucks. It's laborious, time-consuming, and can be expensive considering the cost of cobalt drill bits.
Old Nov 11, 2011 | 11:07 PM
zadeluca's Avatar
i was fortunate enough to have a drill press. i bought a cobalt bit and it was like a hot knife through butter. it was actually quite satisfying after the several days of hammering and swearing
Old Nov 11, 2011 | 11:11 PM
ImTheDevil's Avatar
The drill press must help a lot. We've had to use a hand drill and to be honest, I'd rather **** glass than drill out another pinch bolt. Maybe the ones we've had to deal with were excessively bad, but even using cutting oil, we go through 4-5 cobalt bits on one pinch bolt, which typically comes out as dust and small fragments. Absolutely no fun at all.
Old Nov 11, 2011 | 11:13 PM
ImTheDevil's Avatar
Zadeluca, where in central NY are you? There's a group of us from this forum in Binghamton, a few more in Ithaca and Corning area, couple in the Poconos (90 minutes south of Binghamton), and a few in Syracuse as well. You near any of us?
Old Nov 11, 2011 | 11:24 PM
redmond1501's Avatar
I'm praying to the pinch bolt gods right now because I'm doing my driver's side control arms tomorrow. Last time I went through 2 drill bits dealing with the upper control arm bolt. Maybe my sledge will work this time.
Old Nov 11, 2011 | 11:31 PM
zadeluca's Avatar
yea thats rough. i tried it by hand first because the spindle was so hard to secure to the drill press. then i just said **** it and just held the damn thing with my left hand as i used the press with my right lol. took about 5 minutes for each one and didnt even break the bit (lots of cutting oil).
im around utica. i posted in the regional forum a while ago and dan mcboost messaged me about all the different get togethers around CNY, but i keep forgetting to write him back
Old Nov 12, 2011 | 07:55 AM
  #18
ImTheDevil's Avatar
Yeah I haven't met him yet either. Myself, Hiwords, Devildub, Emilgevor, Meloman, Tware4021, Blacksheep, Frostyflax17, Me_in_NY, and others are all in this area. Let me know if you ever plan to head down this way or if you're just bored with a free day and I'll see about rounding up the guys and meeting up with you.
Old Nov 12, 2011 | 07:33 PM
  #19
I don't think there's any way around the pinch bolt issue.
I drilled my driver side bolt today. After a ton of heat and sledge hammering the bolt moved about .5 mm, so back to the drill. Using proper cutting fluid definitely speeds things up.
Having decent aim helps also -- this time the bit came out through the nut dead center.
Old Nov 13, 2011 | 07:11 PM
  #20
redline380's Avatar
Legal Moderator
well i got another knuckle (it was the wrong one, go figure) so i went to the hardware store, hardware hank, and lo and behold they had the exact bolt i needed in stainless. same length same width same head size. the only difference was they had 1 pitch and the pinch bolt is 1.25 so close enough. but im thinking ill run a lock washer for safety
