ignition problems...
Old Nov 18, 2008 | 01:26 AM
punkrocker5817's Avatar
Default ignition problems...
So the other day my car started running really rough coming home from work. When I got home I checked things out and noticed I smelled gas, and sure enough plug 5 wasnt firing. so I ordered a coil pack and new wires that Ill be installing tomorrow. I also pulled the NGK's I just replaced 2 months ago, and they're all pretty gross. a few are completely black. I took pics with my crappy camera phone. should they be this bad already?
http://usera.imagecave.com/enjoi_311/
If the coil pack and wires dont fix it, what else could it be?
I did replace the plugs with bosch platinum 4's, but of course my coil pack and wires are ripped out. Im curious to see how they do.
Old Nov 18, 2008 | 01:32 AM
EpicWin's Avatar
I did replace the plugs with bosch platinum 4's. Im curious to see how they do.
The ceramic insert should stay white, or better a yellowish orange (indicates you are using quality fuel/additives). Looks like you are running a little rich, from what I cant tell from the pics, but that's a guess (cause the pic sucks) but you say you can smell gas, which supports my idea.
Here's what to do before installing anything:
1. CHECK FOR CODES!
2. swap a coil from a cyl you know to be firing and see if this issue goes away.
3. report back to the forum with findings.
Old Nov 18, 2008 | 09:30 AM
what I found interesting is that 3 are black and 3 are white. My engine light has been on since I bought the car, the owners said it had been on for over 2 years. when I checked the CEL, it came back as o2 sensors, which I will be replacing along with the coil pack and wires. When the engine was running rough, the CEL was flashing. I think the 02 sensors are the original culprit, which is why 3 are black and 3 are normal.
Muniru
Feb 18, 2013 09:36 AM
DEDMN_TT
Mar 18, 2008 01:36 PM
perzianhustla
Sep 23, 2007 09:07 AM
CaliA4
May 7, 2007 02:48 AM
oleafo
Jun 26, 2006 02:42 PM
