Infamous "Belt Job"
Old Mar 14, 2011 | 12:48 AM
s2_Audi's Avatar
Default Infamous "Belt Job"
I took all the plastic covering off my motor today and seen that my belt is cracking, and my water pump is gone. Just courious is it easy to replace both? Im sorry if this is a "noob" post but im new to this whole Audi thing... Any help/advice is much appriceated. Thanks
Old Mar 14, 2011 | 12:55 AM
DAS98A4's Avatar
Not exactly easy if you dont know what you're doing. Go on google and type in 'audi b5 timing belt replacement' ad you should find plenty of DIY's. Ecs tuning also has kits for the replacement. They are usually replaced together.
Old Mar 14, 2011 | 01:02 AM
s2_Audi's Avatar
Ok thank you, you wouldnt happen to kno how much it usually costs to do a head gasket job and a valve cover gasket? Its a 12v v6 2.8 and i just hit 191,000 and everything is going out. I have alot more little problems i want to ask about but i dont want to post alot of different threads :/
Old Mar 14, 2011 | 01:05 AM
chris120391's Avatar
replacing it is not too bad as long as you have basic mechanical knowledge. It's really more time consuming than anything
Old Mar 14, 2011 | 01:58 AM
Andrew149's Avatar
if you have done a timing belt before than you should be able to if you have no i don't suggest learning with out a friend who knows what there doing some say it easy and others have a hard time
Old Mar 14, 2011 | 08:09 PM
RandomAudiOwner's Avatar
Just to impress upon you, if you botch the timing belt job, the engine is junk. It's doable by a newbie, but getting the tensioner down in the right fashion can be tricky. Honestly, at 191k needing head gaskets and a timing belt job, I would just start looking for a replacement engine. Probably an easier job than all that anyway. And possibly cheaper, if you can find a car getting parted out locally.
Old Mar 14, 2011 | 08:59 PM
Aud1A4's Avatar
i had no mechanical knowledge and i still complete my tbelt job completely myself. it was kinda difficult but very time consuming. i would do it again just fir the learning experience.
Old Mar 15, 2011 | 10:15 PM
Mad Cow's Avatar
With the cam locking bar anybody can do a timing belt, there's pretty much no way to screw up the timing if you do it the proper way. Without the bar you're taking a risk but it's still not too bad.But honestly I would be looking at a used motor if I were you, the cost of all that and the time you would need are just not worth it at this point.
Old Mar 15, 2011 | 11:21 PM
s2_Audi's Avatar
Thanks guys, after all the imput i think i might just look for a motor since i do alot of canyon runs and id like to do a "rear mount" turbo before the year is over, any ideas of good places to look for a 12v 2.8 motor (Other then junk yards, ebay, and craigslist) i cant find any
Old Mar 15, 2011 | 11:31 PM
Just be patient and have the cash ready, something will come along. Alternatively talk to an independent service shop, they will have a junk supplier. In northern illinois i use Rockford or PKQ.
Oh, i was thinking of the rear mount set up too, a friend of mine had a retarded fast Camaro with a rear mount.
