Info Center and Cruise Control Problems on '99 B5 2.8L
Old Mar 21, 2008 | 02:01 PM
Boedie's Avatar
Default Info Center and Cruise Control Problems on '99 B5 2.8L
1. My display has some lines that don't seem to work all that well. The screen is kind of garbled.
2. My Cruise Control does not turn on at all.
Are these related issues like a problem with the computer? Or is it 2 seperate things like the CC switch and then just the display going out and I need a new cluster anyway?
Old Mar 21, 2008 | 02:07 PM
vgo's Avatar
vgo
Default RE: Info Center and Cruise Control Problems on '99 B5 2.8L
common problems...do a search...i literally just posted those 2 audi defects on the thread posted as "Audi Defects"
but your answer to your questions..heres what will come up if you use the 'search' feature
1. DIS Display. common, replacement = $400. You could check the wiring if there are any corrosion. But no matter what there will be some straight lines that are black.
2. CC module https://www.audiforums.com/m_483628/tm.htm
and http://forums.audiworld.com/a4/msgs/1996882.phtml
amcclean
Nov 27, 2011 06:22 PM
AudiTurbo
Nov 29, 2010 08:02 AM
AudiTurbo
Sep 25, 2009 05:07 PM
toolagit2qwit
Apr 2, 2008 09:44 AM
Mindless Drone
Dec 23, 2007 02:34 PM
