inner tie rod joint
Old Oct 4, 2008 | 03:42 AM
SuperSquid's Avatar
Default inner tie rod joint
How does one go about removing it from the steering rack?
Do I just need to get a gigantic (1.5") wrench?
Must I remove the shock/spring assembly?
voodoo?
If I had a better cutting tool I would have just hacked it off at the smallest diameter of the shaft and stuck a socket on the ****** but I don't have anything good for that here.
ideas?
Anyone have a pdf version of the shop manual?
Old Oct 4, 2008 | 10:36 AM
manufan's Avatar
You don't need to remove the strut. The VAG tool is a crow foot style open-end wrench with an extension that reaches out past the fender lip. And then it has a t-bar on it. That tool isn't necessary at all. You will need a BMF adjustable wrench. For a reason that only the VAG engineers can explain, the inner tie rod isn't 6-sided, it's 8-sided. So if you disconnected the outer and tried to slip a box-end wrench on the inner, it won't fit.
Old Oct 4, 2008 | 02:02 PM
SuperSquid's Avatar
I assume this VAG tool will run about $300?
The 2 BMF adjustable wrenches I have were both too cumbersome to get into the space and manipulate. That being said they ARE pipe wrenches. I guess I'm heading to find an automotive adjustable.
I hate stupid special service tool crap. I have a feeling I am going to run into that way more than is acceptable on this car.....
Old Oct 5, 2008 | 11:39 AM
SuperSquid's Avatar
This thing is globed in loc-tite, isn't it?
johnnieb
May 31, 2013 12:50 PM
jinsojoo
Nov 11, 2009 05:59 PM
hartsoe1
Aug 25, 2008 07:28 PM
FOZZIE BEAR
Jan 6, 2008 02:07 PM
boastud
Sep 25, 2006 01:31 AM
