installing giac chipped ECU
Old Jul 3, 2008 | 03:14 PM
sakuraba's Avatar
Default installing giac chipped ECU
I just bought a alrdy chipped giac ecu off the net & was wondering after i pull my original ecu is there any due process to putting the giac one in, such as letting the car idle for a while, turning the key till the power comes on but not the engine and letting it sir ETC Thanks! Or can i just give her **** right away?
Old Jul 3, 2008 | 04:21 PM
A4 Effort's Avatar
Default RE: installing giac chipped ECU
I would think that as long as the ECU numbers are the same, that you could just swap and go. I'm not 100% sure. "If"I were doing the swap, i would turn the ACC on for a little bit and then start it up and let it sit at idle for a while. Then go for a casual spin to let the ECU adapt.
fumoazul99
Jul 19, 2008 07:15 PM
germantech
May 12, 2008 02:50 PM
Brandon2000s4
Oct 19, 2007 08:41 PM
Brandon2000s4
Sep 14, 2006 03:08 AM
