Intake Mod
Old Apr 7, 2008 | 12:40 PM
georger's Avatar
Default Intake Mod
I need help with an intake mod, not sure if i should attempt the new filter one, or just drop in a k and n and put a few holes in the bottom of the stock. There are two diy's on this forum, just not sure which one is easier or more effective? I have never attempted something like this before. Any comments, or suggestions would be much appreciated, thanks everyone.
Old Apr 7, 2008 | 01:52 PM
feerocknok's Avatar
Default RE: Intake Mod
Just don't over complicate it. Drill holes through the plastic inner fender and cut out the bottom of the box. K&N is highly advised, especially since they are water resistant, where as a paper filter is paper.
Old Apr 7, 2008 | 01:53 PM
turbo kraut's Avatar
Tech Guru
i personally have done both, and am running the k & n with the front of my box swiss cheesed...
the cone filter will give you a tad more throttle response and make you dv louder.. other than that, nothing
the swiss box and k & n do about the same, but i didn't wanna drill my finder linner.... if you do a oiled filter of any kind, let the filter sit out for a day or 2 to get the excessive oil off the filter or it will eat up your maff for a late night snack
Old Apr 7, 2008 | 01:57 PM
Mathis147's Avatar
def agreee with turbo kraut, used K and N filters on my highly modded 01 celica gts, and my slight modded 02 a6 2.7t, and on both cars i have had to clean the oil off my MAF sensor because when its ***** to the wall pedal to the floor time, that oil will turn your MAF into an oil sump, use oil sparingly and follow kraut's suggestion.
David Narez
Jun 26, 2013 09:20 AM
lukestaah
Jul 28, 2012 11:26 AM
ryanjayblair
B7 Models
May 28, 2009 05:13 PM
apg96
Jun 28, 2005 05:34 AM
